chauvet min spot Topic is solved
bigmark
chauvet min spot
Post by bigmark »
the fs file does not work does anybody have a file to male the min spot work with gobos
Re: chauvet min spot
Post by LJ_krede.dk »
could you tell more about what is not working for you?
You could try to change the fixture yourself to make it work, you just need to open the fixture in fixturecreator.exe and compare the nummbers for channels and dmx values with the Chauvet MINspot Manual
Make sure your MIN spots are running in 13 channel Mode as the fixture in FS are for that, not for 5 channel mode.
I can see that colours and some of the gobos is wrong (or has wrong DMX values) in the fixture compared to the manual, but you can easily fix that yourself (if it was me me I would use the colour wheel settings for the colour macros instead of macros, but that's my opinion)
besides the gobo and colour issue i can see there is 2 more problems with the fixture you can fix yourself.
1: intensity is set to Min= 8; Max= 134 --> Wrong.
The manual says that the lowest DMX value is 100% and the highest is 0% intensity.
change it to Min=134; Max=8
2: Goborot is set to 13, but the feature "gobo rotation" doesn't exist in the MIN spot. remove the number..
I hope you can fix the fixture yourself now (and learn something about DMX and fixturecretor). when you have tested the features, please upload your fixture in the topic "Chauvet MinSpot
if you have some more questions feel free to write again
FreeStyler Version: N/A
Post by remco_k »
bigmark wrote:the fs file does not work does anybody have a file to male the min spot work with gobos
Moved the topic to FreeStyler Fixture Files - Help & Support
bigmark, we don't really like this kind of fixture requests. We encourage people to find out problems themselves, and/or create a working fixture file.
So please dive in (a lot) deeper in your problem (instead of asking for a fixture file) and try to solve it, with our help.
Supplying information to us about your fixture file (like the DMX channel description) helps a lot.
