Hi all
I have raised the following as a bug but as allways will seek your advice.
I get the following error: Run time error "9" Subscript out of range, when adding overide buttons. The first one adds ok but the error occures every time I try to configure a second button.
I am running 2.96f on a 7600 core 2 duo machine with 2gig ram and a nvidia 7950 gtx graphics card. I am runnung under Vista Ultimate.
Any and all suggestions gratefully received.
KevinP
Second question of the day.
- FreeStyler Version: 2.96f
No trees were harmed in the making of this post; however, a significant number of electrons were slightly inconvenienced.
It is cheaper to legislate than educate.
He who dies with the most toys; is still dead.
- Admin
- FreeStyler Version: NULL
Re: Second question of the day.
wow that sounds umm.. yea... you might try to re-install your .net framework??
Matt Hankosky
flickr.com/photos/mattxhank
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Are these old scenes from an erlier version, i find i can have errors after upgrading, try creating new scenes too see if that helps.
- Mattotone
Alternativly, have you been playing with the freestyler ini.
I changed my max number of steps to a high value, and when i installed the new version, the ini was reset. this may be your problem try increasing the max steps.
- Admin
Did this issue become resolved?
Matt Hankosky
