Android remote for Freestyler
cyberb0b
Commited FS Forum helper
Post by cyberb0b »
Is there already an android remote version for freestyler?
I
Or is somebody developing it at the moment?
FreeStyler Remote For Android
https://play.google.com/store/apps/deta ... VybGl0ZSJd
dmxlighting
FreeStyler Version: beta
Re: Android remote for Freestyler?
Post by dmxlighting »
By 'Android' I take it you are refering to the Google mobile phone platform. ?
I would say its not being developed and probably never will be. Its a possiblity that someone might make an artnet control that will work, bit like the iphone software that you can buy for about £50
cyberb0b
Post by cyberb0b »
I mean for the google android mobile platform.
But i dont like paid applications for the mobile platform, cause ist an luxuary item.. not a must.
dmxlighting
Im not to up on the Android thing as I prefer Iphone (the only phone worth having!!!!!)
Am I right in saying its 'open source' ? Maybe somebody will do something one day. Maybe it will be you ?
Just a thought, would the PDA interface work with it ?
cyberb0b
Post by cyberb0b »
yes i do..:)
But i'm thinking already off a apache based website for freestyler.. But i need to do some more investigation. But i think thats not a real problem.....
that can be opend on every pad/pod/wii andsoon can be used.. Pure webbased...
FreeStyler Version: N/A
Post by remco_k »
Its a good idea, as far as my knowledge goes, it does not exists. But a webserver running some custom applications is needed then. Which could be just the computer that is running FS.
cyberb0b
Post by cyberb0b »
True.. The same ting i am thinking.
Mabey a merge with the telnetserver or mabye a own library for apache
cyberb0b
Post by cyberb0b »
I already found another solution.
Fingerplay Midi for android. It makes a connection to the "server" running freestyler.
More info on: http://thesundancekid.net/blog/fingerplay-midi/
For the android users, You know what to do with this :)
dmxlighting
cyberb0b wrote: For the android users, You know what to do with this :)
Ooh secret android code :lol:
cyberb0b
Post by cyberb0b »
saves a lot of typing.
Its an installer code wich you can view with the camera on your phone.
It gets the latest version of the app on your phone :)
FreeStyler Version: 3.3.7
Post by LJ_krede.dk »
Now I'm getting interested. I have a HTC Hero so it could be a cool feature for me as well.
Can you give a description how it works, how well it works and what you can/are controlling via the android phone
/LJ_krede.dk
Aalborg, Denmark
cyberb0b
Post by cyberb0b »
Okay.. i also have an hero.
How it works simply said works:
Install and run on your android phone, fingerplay , that connects to the downloaded fingerplay server on your desktop.
On your desktop you also install a midi loopback.
And in freestyler you open your midi settings,
Press a virtual button on the phone, and its relayed to freestyler.
The connection thru your network is wireless.. The communication with the server is very good,
performance in freestyler.. Works also.. Not perfect, but i am still fine tuning it.
The interface looks like this.
and there is an button page.
I played with it yesterday and had some issues.
1) i got alot of FC's (for non-android users it means Force Close --> crash)
2) when you are using the buttons which is working like override buttons in FS, nothing happens
- this is because the midi value dont reach 127 and it is random, around 60
otherwise it works great and I think I may want to use it some day. one down side is you have to have a wireless AP with you. I tried to make a wireless ad-hoc network on my laptop but the android (or HTC ??) software cant see the network. I have the program "wifi analyzer" on the phone which could thoug.
/LJ_krede.dk
Aalborg, Denmark
cyberb0b
Post by cyberb0b »
I am also still perfecting it. But a moving head has just died, so this is secondary priority.
First i have to make the mh.
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
im looking to move over to the android platform, and since they dont require a mac to program on it and the $99 fee. Givven some free time i may be able to start knocking something up.
Post by Mattotone »
