Lockup when adding fixtures
heeroyuy
- FreeStyler Version: 3.2.1
I'm using the latest version of freestyler. Every time I try to add fixtures or to modify one in fixture editor both programs lockup when it trys to load the image. I have searched through the forums and I haven's seen where anyone else has had this issue. I wanted to see if anyone had any ideas.
- FreeStyler Version: 4.01
Re: Lockup when adding fixtures
Do not have Freestyler open when using fixture creator. Fix the file THEN open Freestyler
heeroyuy
it's not with the two programs open at the same time. It just occurs with both programs.
- remco_k
- FreeStyler Version: N/A
How large is your image? (Bitmap file size and pixel size)
heeroyuy
it's with the default fixtures or any fixtures for that matter. I can browse the manufactures when I go to add/remove fixtures but ass soon as I select a fixture its self the program locks up. On a side note. I can build a location file on another machine and load it without any issues.
- remco_k
Okay, so it is definately not something in the fixture files, but somehow you only have that problem with that particular installation of FS and don't have the same problem on another machine. Right?
You could try reinstalling FS (make a backup or rename the FreeStyler directory as a backup) and see if the problem persists.
matt
- Admin
- FreeStyler Version: NULL
If you are useing Vista or 7, make sure to install to c:\freestyler as there are known issues with installing it in program files.
Matt Hankosky
flickr.com/photos/mattxhank
