20 Foot XLR $4 @ Pssl.com / Till Nov 30 (monday)
matt
- Admin
- FreeStyler Version: NULL
Matt Hankosky
flickr.com/photos/mattxhank
- remco_k
- FreeStyler Version: N/A
Re: 20 Foot XLR $4 @ Pssl.com / Till Nov 30 (monday)
Wow, thats cheap.
Still, maybe obvious, this is no DMX cable. So I would'nt risk problems buying it for light jobs.
- dmxlighting
- FreeStyler Version: beta
Dirty 485 (sorry DMX) will work just fine over that cable. There are only really issues with crap (sorry cheap) cable over very long runs or if you have a LOT of fixtures. In any case a dmx terminator would probably sort your issues if you get any!
Just as a point - I use universal 1 pair + screen, its good for audio and lighting alike, infact I use it for all sorts!
I use it for commercial installations and have never bothered with a terminator and never had a problem.
Its worth mentioning that I only ever use Neutrik xlr's - nothing else comes close! The connectors on the cable on that link look like shite ones!
matt
- Admin
im with DMXLighting,
I use "audio" xlr's all the time for DMX and never had an issue.
Its a lot easier to stock one type of xlr cable and use it for either purpose.
Matt Hankosky
- remco_k
I know, it could (and often will) work good. Still there is a big technical difference between regular low-cost audio cabling or real DMX cabling.matt wrote:im with DMXLighting,
As stated, in tiny universes it would'nt make a difference most of the time. But problems may arise when using larger setups.
I like to play on safe, always. Because if there is a problem, it can be too late to do something about it.
