What up with this “Off Line Mode”
Locked
yofo
Post by yofo »
What up with this “Off Line Mode” and then I see all this ! marks everywhere
And what does the buttons do next to the sliders and other stuff, it says “Off, Snap, Fade” what does it mean?
FreeStyler Version: N/A
Re: What up with this “Off Line Mode”
Post by remco_k »
yofo wrote:What up with this “Off Line Mode” and then I see all this ! marks everywhere
You did'nt read one word from the manual did you?
"Offline mode": direct copy from the manual: "When the Cue window is opened, or another sequence is running in the SequenceCreator,
it will open in Offline mode. This mode won't change the output to the interface nor interfere with running sequences."
The ! marks: direct copy from the manual: "This icon indicates that a manual override is active, click on it to disable the manual override."
Its all in the manual and in the different guides that step you through FreeStyler, so I suggest you just RTFM!
Because all of this is heavily and well documented on the web and in the manual, I'll close this topic.
Locked
