the only thing stopping me from freestyler is this not being there
i need the template for freestyler and the 3d visualister
ACME Imove 7S Topic is solved
- remco_k
- FreeStyler Version: N/A
Re: ACME Imove 7S
Moved the topic to the FreeStyler Fixture Files - Help & Support subforum.
You can create the fixture file yourself using the fixture creator, so nothing is stopping you from using FreeStyler.
Creating a fixture file is easy, so go ahead. Ofcourse don't forget to post your created fixture (and exported as *.pff) in de user created downloads subforum.
See also: Can't find your fixture in FreeStyler or on this forum?
