Hi, I saw that there is a window to control fog/haze machines. I have a DMX haze machine and want to control it via this window because the timer function is very intersting. But I don't know how to assign the fog window to the dmx address. In other words, how the window knows which fixture to control?
Also, why are we limited to 20 sequences?
thank you
mike
fogger window Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: fogger window
Freestyler will automatically assign the window to the correct address.
But you will need to add a fogger fixture in the same way any other light would be added.
You are not limited to 20 ques, free styler can only show 20cues at a time, use the fast que switcher on top of the cue manager window. Alternatively you can use the sub masters.
