Following upgrading to 2.96f my fixtures have "disapeared* from freestyler.
I have copied both que and chase foldes and freestyler.ini, chasers.set, groups.set and data.fsd.
All the original fixtures are still pached and all my groups still exist. I have no idea why they are not displayed on the workspace (background).
I have reported this as a bug but am also open to suggestions from the rest of the community.
Regards,
KevinP
Any Suggestions?? Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Any Suggestions??
if you still have the other installation do an export an import into the new version. You may have missed a file in the backup.
Have you tried adding the fixtures manually.
I doubt this is an actual bug because your method of backup is not the recommended way.
Have you used any custom fixtures gobos not included in freestyler. if you have not backed up these files i imagine that the fixtures will not show.
Kind regards Matt
Kind regards Matt
SevenK
Thanks for the reply.
I uninstalled and reinstalled Freestyler 2.96f Loaded in my backup files as above and all is well.
I still have no idea what the problem was but it has gone away.
KevinP
KevinP
- djSupport
NiceNo trees were harmed in the making of this post; however, a significant number of electrons were slightly inconvenienced.
matt
- Admin
- FreeStyler Version: NULL
hum sounds weird. a 1 must be a 0 lol maby you might try deleting the fixtures and re creating them.
Matt Hankosky
flickr.com/photos/mattxhank
