FS 3.2.1 Up - Seq's stops Shapes
Disscussions on possible bugs in the current BETA.
YOU MUST FILE A BUG REPORT HERE before discussing possible bugs.
The Idea of this is :
1. Informing others of confirmed BUGS and
2. Giving other members the opportunity to confirm your possible bugs
Mike Vaghur
Post by Mike Vaghur »
After FS Update from 3.0.1 to 3.2.1 I faced with a bug - my previous CUEs doesn't work as should.
I have 1 or 2 sequences with movement shapes running. And starting of another ones with gobo or shutter channel only stops my movement shapes (multiselect enabled). All seq's have been checked for channels that should be Off.
Does anybody faced with this problem?
PS: I installed the new FS over the old one. The bug happen with one sequence with edited moving shapes constantly on 3rd step and till the end.
PPS: For new updates: Maybe shape On\Off status should be visually signed and written into seq's like for all other channels (Off\Snap\Fade)
Return to “Latest Beta Bugs”
