Upgrade advice - 3.0.1 to 3.2.1
Qpid
FreeStyler Version: 3.0.1
Post by Qpid »
I currently have v3.0.1 installed as a first-time install.
I want to upgrade to v3.2.1 and was wondering on the best way of doing it.
Do I need to uninstall v3.0.1 first, or just run the v3.2.1 install to overwrite?
How does EasyView cope in the upgrade procedure?
Many thanks,
Qpid.
dmxlighting
FreeStyler Version: beta
Re: Upgrade advice - 3.0.1 to 3.2.1
Post by dmxlighting »
You should be able to over write your existing fs install without any problems. Its always a good idea to make a backup of any files you have created, just in case!
There are no issues with Easy View. You dont need to reinstall it and your stages should still be there.
Ive been beta testing FS and every new beta has installed over the top of the last and Ive never had an issue.
Always backup to be sure!
