small issue when selecting and adding fixtures in 3.2.1 Topic is solved
ko stradivarius
Post by ko stradivarius »
I just upgraded to 3.2.1 and now when adding a fixture, whenever I select one from the list, it does not become highlighted until after I click on it several times. The fixture does actually select and can be added the first try, it just doesn't highlight.
FWIW, im running FS on a Samsung NC10 netbook. I wiped the drive and re-installed XP and it still happens.
Like a said, not a huge deal but figured Id make mention since a search didn't produce anything.
dmxlighting
FreeStyler Version: beta
Re: small issue when selecting and adding fixtures in 3.2.1
Post by dmxlighting »
Ive seen this happen too.
Its not really a problem but I will send a bug report to Raph.
Like you say it still selects and imports the correct fixture it just doesn't always highlight it.
