ROBE Colorspot 170 AT
jannoposti
Post by jannoposti »
Maybe someone know where I can get fixture file for ROBE Colorspot 170 AT.
Thank you
FreeStyler Version: N/A
Re: ROBE Colorspot 170 AT
Post by remco_k »
There are 2 ways:
1. You can find it here on this forum.
2. If 1 does'nt do its job, you need to create the fixture file yourself using the fixture creator, which is not that hard to do.
It seems that the 170 AT is'nt there. Maybe the 150CT is the same and works, or you can use the 150CT fixture file to get started or take it as an example.
So, get the DMX channel description of the 170 AT and give it a go and I hope I'll see you posting a new fixture file.
If you get stuck, ask here in this topic with as many as information as possible and post the fixture file with it that you have created so far.
(see the forum rules in red at the top of your screen)
