hallo iedereen,
Ik wil gaan draaien met touch screen en ik heb het al bekeken maar ik heb wat vraagje's:
Is er ook iets waardoor je de chase's kan aanpassen qua snelheid en tap.
zijn er ander interface's beschikbaar die andere knoppen heeft.
Dit waren ze
Jory
Hey everyone,
Ik want to use a show with a touchscreen and i already previewd it, but i got a few question's
Is there someting so you can adjust the speed of chases like tap or a level bar.
Are there any other interface's for touchscreen that have orther buttons.
these were my questions
Jory
Touchscreen interface
- FreeStyler Version: 3.0.1
- dmxlighting
- FreeStyler Version: beta
Re: Touchscreen interface
Its better to use a midi controller like a BCF2000 to adjust the speed on a chase as it has proper faders and would be the easiest and most effetive way.
You can control sequence speed and master speed from the touch screen 2 interface in FS - you will need to build the screen setup from scratch.
hello
i saw this in the freestyler ditectory--> images--> touch. and there was a background for a touchscreen. is it possible i can use that in touchscreen 2??
Jory
Jory
- dmxlighting
hi yes you can ONLY use that for touch 2. just rename the file you want to use as 'background'
