Enttec Pro Dmx in Topic is solved
BriteLighting
Enttec Pro Dmx in
Post by BriteLighting »
Hay guys im loving freestyler i just used it for a huge dane competition in a theater
with midi in but i was just wondering if DMX in from enttec pro will ever be posabile then Freestyler would be perfect Thankyou :fs:
cyberb0b
Commited FS Forum helper
Re: Enttec Pro Dmx in
Post by cyberb0b »
Correct me if i'm wrong,
But the enttec pro dmx does only support DMX in Or DMX out.
So if you want in and out, you will need a second one.
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
cyberb0b wrote:Correct me if i'm wrong,
The question was will fs ever use enttec dmx in. At present its no but who can say what the future holds............
BriteLighting
Hay guys. Thanks for the quick replys i have 2 interfaces 1enttec pro and 1 velleman
what i was hoping to do is use the velleman as output and enttec as input
I just got the enttec pro and loving it thanks for all the help :D
FreeStyler Version: N/A
Post by remco_k »
BriteLighting wrote:Hay guys. Thanks for the quick replys i have 2 interfaces 1enttec pro and 1 velleman
I can tell you one thing out of my own experience: you don't want to use the Velleman VM116/K8062 interface at all. Especially not when using quite a lot DMX channels (e.g. >100). The thing is way too slow. You might want to test if you experience the lack of speed/response at your setup, before it is too late. (do a full test with all lights on and running, as that makes a difference)
I've had situations where it took >500 msec between I pressed some override button that flashes a light and the actual flash. In fact, every communication took 500 msec...
Trust me, you don't want that. Search this forum for the VM116/K8062 interface when you want to read my investigation for this problem for it.
BriteLighting
hi man thanks for the info and yea the velleman k8062 got some lag allright at one point there i had about 1 sec lag i was running 60 dimmer channels and 24 led par64 but it did the job lol but the enttec pro is worth the money for shore.
