Manually updating scene's (used to be offline mode)
reg
Has mastered Fixture Creator
FreeStyler Version: 3.2.8
Twitter: twitter.com/regorton
Post by reg »
Hi Guys,
Is there a way to manually edit the scenes?
I loved the old offline editor. Am I right in thinking that this feature has gone from the new (3.2) offline edit mode screen.
Cheers
Reg.
p.s. Used my simple freestyle for a show tonight. It worked (kind of, just one bug).
FreeStyler Version: N/A
Re: Manually updating scene's (used to be offline mode)
Post by remco_k »
Offline mode still exists, but just without the matrix with all the numbers. You can use the default fixture controls to edit the scenes like you do when you program a scene online.
When you start 3d easyview next to it, you can see what your offline changes do, while FreeStyler is still running the cue program on your DMX device.
reg
Post by reg »
Cheers,
Is there any way to get the matrix with the numbers back by clicking something else?? I really used that feature all the time!!! :?:
Or is there a way to manually edit the sequences in notepad or similar?
Reg
