Hi guys,
At first I still would like to thank Raph for all his great work and all his spend time in this great project.
I am a freestyler user since the beginning and I really can say: thumbs up for Raph.
So that's the good news: Lol.
I was wondering or asking, perhaps this functionality does allready exist?
My dmx setup is growing and growing and growing. So what's the problem. I am using 16 led pars. I made sequences for these pars. A couple of 7-8 pieces. So I would like to loop all these sequences in one cuelist so I don't have to look around for the pars. They can do their own thing so.
But I do want to be in control of my other lights. So when I switch to another cuelist and also select another cue for another kind of light, these sequences are also being looped. And that's not what I want. I only want the led pars to loop al my sequences, not my other light sequences.
Is there a workaround for this? Using the submasters doesn't solve the problem when having loop all sequences selected.
So I guess, I would like to see a loop all sequences option to be enabled or disabled for every cuelist?
EDIT: It seems now, when I switch from a cuelist, for example sequence 6 was playing at cuelist1, when I switch to cuelist2, the button of sequence 6 is also indicating that this sequence is playing. Is this a bug? Because when I switch from cuelist I do want to see which sequences are playing or not....HELP!!!!!!!
Loop sequences or not per cuelist
magic
- FreeStyler Version: 4.1.6
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Loop sequences or not per cuelist
i was thinking the very same thing on saturday night,
wouldnt it be great if you could get the submasters to loop.
i have sub masters for colours, movements, shutters+strobe.
it would be nice if fs would allow you to select submasters to loop, i.e colours, movements and then i can select the shutter sequence i want.
a request that hasnt come up is the number of iterations a single sequence should make before it goes onto the next.
Stikstof
1 more vote for this request.
either to make it possible in all the cue lists, or in the submasters window.
