Hi, How do you install plugins on FreeStyler, like the TCP/IP server
Thanks!
How to install Plugins Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: How to install Plugins
the tcp ip server was created before plugins just run the exe and it will connect to freestyler
