Hi Folks...
So I've created a whole bunch of sequences but am wondering if their is a way to add a different sequence onto the end of another?
Why...
Well, sometimes I have to walk away form the pooder and it would be nice to know that I have a nice long sequence to entertain the crowd while I'm away. I know how to increase the number of steps in a sequence but being able to join them togeather would be really handy.
Thanks in advance!
Re: Joining Sequences Togeather...
- Kings
- Commited FS Forum helper
- remco_k
- FreeStyler Version: N/A
I don't think there is a way do join sequences together in one sequence.
But there is a way to play several sequences after eachother. That can be done in the cue window.
GaryBonaducci
Yes, using the "Loop all sequences" option in the Cue window is the easiest way. Sequences have limited number of steps, so you'd run into problems anyway if you tried to join several sequences together into one long one. Make sure you are running the latest version, 3.2.1, because the Cue window in earlier versions had a small issue with running this option. The latest version makes looping sequences through the Cue window a lot better and easier.
