Hi ppl,
At all versions i have a big problm... when i change a botton of the cuelist , they disable my submasters that are playing ate the same time... So i need to go at the Submaster window and pres "run" again. There is any way to use the two ate same time?
I use de bottons to the leds(bars, par64)... it is a fast way to change it, the submasters have sequences of the movingheds(movement, colors, gobos).
If i press cuelist botton->submaster, works ok. But if press submaster->cuelist button, stops the submaster.
help please.
Cumprimentos
Cuelist buttons and Submasters
- aquas
- LJ
- FreeStyler Version: 3.0.1
