Hello!
First I would like to say FreeStyler is AMAZING!
I use freestyler for live music use. I use it with a coverband and I dont program anything, i just do it "freely" because i know all the songs. I use 6 Elation Design Spot 250's and 4 Elation Design Wash 250's.
My question is, when you go to turn on the automatic shapes, they always reset the speed to 1000. So everytime i go to use a shape, i have to quickly return the speed to the value i want it. I do this so all the fixtures dont move at the same speeds. Is there a way to get the speeds to stay the same as when i first set them?
Thank you for the help!!!!
Brandon M
OverExposure Stage Lighting and Photography
Appleton WI, 54911
Keeping the automatic shape speeds the same?? Topic is solved
- remco_k
- FreeStyler Version: N/A
Re: Keeping the automatic shape speeds the same??
Save the shape in a sequence and all parameters will be saved.
Then run that sequence in the cue and you're done.
