Freestyler and pangolin QM2000.net DAC?
cyberb0b
Commited FS Forum helper
Post by cyberb0b »
Cause i own few qm2000.net dacs with dmx output, I have asked the following question at pangolin;
Is there something of an virtual dmx driver for the qm.net so i can use the qm.net with freestyler? Use the lasers
for what they are build for, and use freestyler to use the qm.net dmx output?
To make things clear. Pangolin produces laser hardware and software. qm2000 is a dac with dmx output. the ".net" is an extention board to make the system ethernet compatible.
Cause there is no better laser software than pangolin (my oppinion afcourse), i would love to se that freestyler uses my dmx output of my qm2000.net.
Pangolin it self doesnt use the dmx interface in there software extensively, so there internal dmx support is pour.
And then came the following reaction ;
Hi Bob,
You have an interesting idea. In fact, the Freestyler people could -- if they so chose -- control the QM2000. It is very easy using our LD2000 SDK.
Perhaps if you suggest it to them, then they can pick up the ball and contact us, and then we make the world a better place ;-)
Bill
I'm not an coder. I don't know where to start, but this msg came from the owner of pangolin him self, so there intentions are serious.
I love to see freestyler work with the DMX output of de QM2000.net.
Is there somebody who can give me a step stone?
Best Regards,
Bob
FreeStyler Version: N/A
Re: Freestyler and pangolin QM2000.net DAC?
Post by remco_k »
I think LJ_raph can.
Try sending him an personal message. Maybe he'll pick it up.
Edit: ow, for some reason this topic showed up as new posting. It was a bit older than today... :mrgreen:
cyberb0b
Post by cyberb0b »
Onge wrote:I agree with cyberbob about Pangolin software being teh best for laser shows, it beats everything hands down (again my opinion).
If Bill has mentioned for LJ_Raph to get in contact with the possibility of controlling the QM2000 from within FreeStyler then that is a big thing and should not be taken lightly at all.
Not only your opinion :D
djlorenz
Post by djlorenz »
if it's also possible with Fiesta.net dac... it's ethernet and it has dmx in/out... i use it for lasershow and i love it... that will be very nice to add a professional dmx control too!
