This is a set of GIF buttons for use with FixtureCreator. There are 20 buttons numbered from one to twenty that say "Pattern ##".
To use them, place the GIFs into the "C:\Program Files\FreeStyler\Gobos" folder, or "C:\Program Files (x86)\FreeStyler\Gobos" for 64-bit Vista. When you're in FixtureCreator's "Macros" tab, they should automatically appear in the right-side list.
Numbered "Pattern" buttons for FixtureCreator
- GaryBonaducci
- DJ
- FreeStyler Version: 3.3.7
- GaryBonaducci
- DJ
Re: Numbered "Pattern" buttons for FixtureCreator
Ha ha... Okay, I'll simply say "FreeStyler program directory" from now on...Onge wrote:Just a quick note on the locations here.
On XP the default location of my install of 3.2.1 was C:\FreeStyler
