IMG StageLine LE-504 - 4 x spot
Crusty Roadie
Post by Crusty Roadie »
My first fixture! :D
The strobe sliders and buttons are used to control the chase and fade speeds.
Macros are there for setting Chase mode, Fade mode and for turning all lights on.
There is a fader to control output intensity.
There are 2 colour sliders:
First colour slider is for producing uniform colour wash instead of operating in chase or fade modes.
Second colour slider is for changing the Chase/Fade sequence.
This fixture has been fully tested and found to work excellently.
Edit: Updated fixture file beacuse I incorrectly said it wasn't tested in the description.
img_StageLine_LE-504.pff
IMG StageLine LE-504 fixture. 4 x spot/fader/colour wash with chase and fade.
(14.25 KiB) Downloaded 26 times
