import/export Topic is solved
- remco_k
- FreeStyler Version: N/A
Re: import/export
No, all these applications have their own way of saving things and internal processing (like pre-defined shapes). As far as my knowledge goes, I don't know any existing tools for converting complete shows between these applications. I even think it is impossible.
You need to build a show from scratch.
