problems with chaser
djmaq
FreeStyler Version: 2.96h
Post by djmaq »
I use six heads (MAC 250 Krypton). Normaly the shutter is closed so I can open the shutter from speacial groups (for example group odd: all heads with odd numbers (1,3,5), group even: all heads with even numbers (2,4,6) or group all: all heads) with an override button.
Then I programmed a chase called mask which is workin so: first step: all shutters are closed except shutter one. Shutter one is open. second step: all shutters are closed except shutter two. Shutter two is open. third step: all shutters are closed except shutter three. Shutter three is open. ... ... step six: all shutters are closed except shutter six. Shutter six is open. The chaser is stored on chasebutton sixteen. If I push button sixteen it begins to work. If I push button sixteen a second time it stopps work but if it stops one shutter stays open. If I stop at step two shutter two stays open. If I stop at step three shutter three stays open ...
What can I do that all shutters closed when I stop the chase?
Hope you can understand me. Sorry for my bad english! :cry:
Android Dev (Moderator)
FreeStyler Version: BETA
Re: problems with chaser
Post by Mattotone »
in the cue manager, on option sixteen select the blue curved arrow, this restores to the original value when the scene stops.
Matt
djmaq
Post by djmaq »
Many thanks! It works fine!
djmaq
Post by djmaq »
HEy Guys.
Another question to this problem. It's the same chaser but I want to stay all chasers open after stopping the chaser by preesing the chase button a second time. Because of this reason: If the shutters are closed, I can't use the automatic dimm function and I have to re-open all shutters before I'am able to continue the show. So I like to stay the shutters open after stopping the chase. Any ideas?
