Hi!
I'm new to freestyler and use it actually only with the virtual interface.
I have programmed some sequences and saved them in a cue. When I start them in the cuelist they work fine as they do when I double-click them in the submasters.
But there's something strange in the submasters: I have loaded my cue and tested every sequence by double-clicking everyone. So far, so good. When I click on "Run"-Button the first sequence starts, and when I click on "Go" the marker steps to the next sequence, but the fixture icons will remain on the first sequence. Same thing when I click "Go" again, the marker steps to the next sequence, but the fixture lights remain as on sequence one.
Is this a bug?
In the end I just want to step to the next sequence by simply clicking one button or, just easier, by using the keyboard.
Thank you!
Lemon
Submasters: "GO" won't work
lemon
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: Submasters: "GO" won't work
it is not a bug. "Go" and "Back" are used to go up and down in the submasters sequences, and "Run" to run the selected sequence. i use the "go" and "Back" when i'm controlling my lights from a MIDI controller. there is no way to shift to the next sequence without using more than one command. and then again. if you are using the cue window and have deactivated multiselect you can just press on another cue, which will stop the previous sequence and start the selected one. you can also assign keyboard short cuts for this, let say key 1 to zero as sequence 1 to 10.
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
