When i double click on freestyler it opens and the loading bar gets 80% of the way over and then my pc reboots. Please help
ThanKS
jOHN
loading the newest version of freestyler Topic is solved
- djSupport
Re: loading the newest version of freestyler
2.96f ??? whats your system you are running and did u reboot before starting it up??
- djSupport
log into chat room...
- djSupport
i waS a little slow logging in i did then u left!!!
kindlefire
i'm running
3.0 Pentium D Dual Core
Asrock 880 Dual Pro
Ati Radeon 9250
Windows XP Pro
1 Gig 400 Mhz
Nuendo Software for sound production
Tricerasoft Swift Eltie for Dj
Freestyler 2.96f
Freestyler was running well before i installed the new update, i downloaded 2.95f and it is working fine but when i run light to sound it crashes. Also what do you have to do to make Led Par cans sync up with sound to light what are the steps.
John
Asrock 880 Dual Pro
Ati Radeon 9250
Windows XP Pro
1 Gig 400 Mhz
Freestyler 2.96f
John
genesis
genesis
matt
- Admin
- FreeStyler Version: NULL
it shounds like a issues with dual core processors.. at least that is what looks as a common.... what i tell people with issues is try to install newest .net framework.
Matt Hankosky
flickr.com/photos/mattxhank
