Hi, I use some fixtures (Moving Heads, Dance floors and PAR64) in Sunlite with specific libraries, developped for Sunlite. The name of the manufacturer is not a stardard one. Not listed at all, not in Sunlite, not in Freestyler.
Is it a means to import or use those libraries into Freestyler ? Or is it a means to get a quite standard library (basic functions) ?
Bonjour, j'utilise des systèmes (lyres, pistes de dance et PAR64) dans Sunlite avec des librairies développées par le fabriquant pour Sunlite. Ce fabriquant n'est pas dans la liste des fabriquants standard, ni dans Sunlite ni dans Freestyler. Existe-t-il un moyen d'importer ces librairies dans Freestyler ? ou bien existe il un moyen de sélectionner un appareil "standard" (fonctions basiques) ?
Bob.
Import from Sunlite library ??? Topic is solved
- remco_k
- FreeStyler Version: N/A
Re: Import from Sunlite library ???
Not quite sure if I understand your question correctly.
I can't speak for sunlite but can for FreeStyler.
If you have fixtures that are not listed in FreeStyler, and can't find them on this subforum, you need to create the fixture files yourself. Which should not be that hard when having some basic DMX knowledge.
I guess for sunlite it goes the same.
