Eurolite SCY-100 RGBW Topic is solved
styloarmani
Post by styloarmani »
How can i use Eurolite SCY-100 RGBW in Freestyler. It doesn't work here!
I don't see this type in the list.
Please can anybody help me?
Reason: Moved the topic to the Help & Support subforum
FreeStyler Version: N/A
Re: Eurolite SCY-100 RGBW
Post by remco_k »
styloarmani wrote:Please can anybody help me?
Yes, you can.
As no one else is going to make the fixture profile for you, you would have to do that yourself. When having some basic knowledge of DMX, you should be able to do that in about 15 seconds. Which is actually faster than me writing this post. (And I write damn fast)
Since you seem new to FreeStyler, I'll hand you out a little guide:
1. Read the forum rules that are in red at the top of your screen.
2. Get the manual of your fixture and lookup the DMX channel description.
3. Start the FixtureCreator (located in your start menu under "FreeStyler").
4. Create a new "Parcan, dimmer,...)
5. Fill in all needed fields, the data from step 2 goes to the Total channels field and the Channel description tab.
6. Save it.
7. (Re)Start FreeStyler and have fun with your fixture.
8. If it works good, please post your exported fixture profile (*.pff) to FreeStyler Fixture Files - User created Downloads in the right section, so other people can benefit from it.
Paperinik
Post by Paperinik »
Here we go!!!
For all You kuky owner of this fixture!
Peppofeu
SCY-100.pff
(77.2 KiB) Downloaded 257 times
siggy019
Post by siggy019 »
fixed some macros (16-32)
Eurolite-SCY-100.pff
(77.37 KiB) Downloaded 63 times
siggy019
Post by siggy019 »
version 2.0 tested on 3 partys
SCY-100 v2.0.pff
(80.33 KiB) Downloaded 71 times
