Tap Sync Topic is solved
byoung85
Tap Sync
Post by byoung85 »
Is there any way that you can set up a sequence and not have the tap sync button affect the speed of the sequence?
FreeStyler Version: N/A
Re: Tap Sync
Post by remco_k »
byoung85 wrote:Is there any way that you can set up a sequence and not have the tap sync button affect the speed of the sequence?
In the current release, there is not.
In the next release (which currently is a beta), you can set a cue (sequence) to ignore the tap button.
