divine lighting Hyper 363 Topic is solved
aemzxd
Does any one have a profile for a divine Hyper 363 light . I know it is proable a cheap light but it is want they are useing. It has 6 ch Dimmer , red , blue , green . strobe , and marco . I don't know if I get the manaul if I can inport it to get it in to the specs in there . I can't seem to find a 6 ch par light to edit . All the led pars I see anly havw like 4 ch's
- remco_k
- FreeStyler Version: N/A
Re: divine lighting Hyper 363
* Moved post to FreeStyler Fixture Files - Help & Support subforum
Hi, try making the fixture file yourself using the manual of your fixture and fixturecreator.exe.
If you fail to get it to work, then post the .pff file here, together with the manual or good DMX Channel description and we will help you out.
