cue autoplay? stop? Topic is solved
crazyhellos
cue autoplay? stop?
Post by crazyhellos »
Hi everybody,
I've been working with freestyler for a few days and making sequence and cue's is no problem, but now
I'm trying to use the cuelist buttons so that I can select a certain sort of mood program. Programming the
buttons is something that also no problem, but when I press a cuelist button all the sequence's that
are under that button are played automatically. Is there a way to stop this, so that when I hit a cue
button the programs waits until I select wich sequence I want to play.
Hopefully you guys know what I mean
Shannon D
Re: cue autoplay? stop?
Post by Shannon D »
Your not alone. I get the same results. It would be cool if it would just load when you click the Cue list button. It would also be nice to have a button up front to loop all sequences instead of going to the cog wheel. And while I'm wishing, the loop all sequences should be in the keyboard & midi assignment list as well. ;)
schoeni907
Post by schoeni907 »
Hello,
does anybody of you get a solution of this problem? If yes, please tell me.
Post by LJ_krede.dk »
The cuelist buttons work that way: all the sequences in a cue which is assigned to a cue list buttons will all be played at the same time.
if you have more than twenty sequences (which is the limit for the cue) you can us the fast cue switcher or even better the submasters. you can read more about that in the Help --> Contents in Freestyler
