Is there a way to change the default setting of the Pan & Tilt speed (in the P/T window) from 1000 to something slower? Even if you change the speed before you turn it "on", the set point changes back to 1000. That's a bit fast. I would rather see the default setting be more like 250.
Shannon D
Pan / Tilt Speed
- Shannon D
- FreeStyler Version: 3.3.2
- I Use FreeStyler for: Band
