hello together,
I'm new here and have a question.
I
2x GLP Pocket Scan DMX
2x Revo 3 DMX
2x Pro lightmaXX SRL-562 Strobe DMX
2x srl-439 dmx Double Derby
1x Antari Z-1200
These devices also work very well with freestylers.
I have 2 x Elation Prob bar 4 how can I use these in the freestyler?
Thanks for your help
Lemy
elation pro bar 4 Topic is solved
Re: elation pro bar 4
Hi Lemy and welcome to the FS forum.
There is several ways you can control them in FS. What i do is to patch each DMX channel from the bars to par cans fixture in Freestyler:
Freestyler also have a fixture for 4 par cans you can use instead:
(Remark: The pictures of "Add/Remove fixture" windows differ from Freestyler 3.0.1 because I have a beta version, but works the same)
I like to patch each dmx channel to a fixture in freestyler because you then can use the FX generator and i can control each selected DMX channel from my MIDI controller.
Hope that gives you a clue how to control the Pro Bars. Otherwise ask again.
I have four of these myself if you are thinking of this one (just with IEC output for each Channel in stead of Two three prong Edison sockets per channel):lemysys wrote: I have 2 x Elation Pro bar 4 how can I use these in the freestyler?
lemysys
Hi LJ,
Thank you for your help it works.
What has struck me that if I speak to the right bars, because I can not define macros, which still seems to a bug.
have nice day lemy
have nice day lemy
I'm glad i could helplemysys wrote:Hi LJ,
I'm not sure what you mean?What has struck me that if I speak to the right bars, because I can not define macros, which still seems to a bug.
