Submaster problems Topic is solved
MrJay
Submaster problems
Post by MrJay »
Hi I'm having a rather annoying issue that I'm hoping someone might be able to help me with whenever I try to use the submasters while using S2L
I can select the first scene fine but then if I try to change to a different scene the output from the submaster seems to die is it something I'm
doing wrong or will I need to submit a bug report? :shock:
Cheers for any help :)
