a fixture with 96 channels
oneoft
- FreeStyler Version: 3
- Twitter: twitter.com/oneoft
I need to create an fixture with 96 dmx channels, but the creater allows only 33 channels is there an way to create an fixture with 96 channels?
oneoft
Re: a fixture with 96 channels
the fixture is an LED RGB Panel with 96 channels also 3 channels for one LED.
oneoft
Were to get that suntrix plugin?
I will check the option when we have assembled the LED Panel, that will be this weekend.
- remco_k
- FreeStyler Version: N/A
The suntrix plugin is in beta stage at this moment and only available to beta testers.oneoft wrote:Were to get that suntrix plugin?
Somewere on this forum you can sign up to be a beta tester.
