I need to set up a cue that runs through multiple sequences all at certain amounts of time. Its for a large art installation so i cant really manually change sequences....its got to run automatically (over the course of like 6 hours).
The Loop All Sequences button DOES NOT WORK??!! I have seen this problem in another posts, but i just cant believe that there isn't a way around this that i have not figured out yet.
I have tried installing other versions of FS, but they have their own problems it seems (I could only find 2.96j for a download and entering in elapsed time did not seem to work?!)
this is incredibly frustrating that two different versions of fs are preventing me from doing what i need to do with two different problems.
can someone help me PLEASE?? or let me know where another version is that I can download?
HELP ME....DEADLINE COMING!! Re: Looping all sequences prob Topic is solved
Tom
Re: HELP ME....DEADLINE COMING!! Re: Looping all sequences prob
I won't be able to have a fully detailed look until later on today/tonight but will have a look and try to get back to you ASAP.
When is the deadline?
Failing that you could use a program which will record all mouse movements and set this to play back. So you record yourself setting off all the sequences, then hit play and the mouse will move itself. Called an auto mouse or something like that.
Again I will look more in depth later.
aslaug1
Tom, Im not sure exactly what you meant by the "record mouse movements" thing? I think you mean that I could devise a way to record the show by recording my mouse strokes. The problem with this is that I'd have to sit here for 6 or eight hours and record it. This could work I guess, but its not exactly ideal and doesnt leave much room for customizing later if i need to change something.
My ent tec controller seems to be working fine, although it is not connected to my lighting at the moment (I dont think this should make a difference, although I will test this in the meantime)
under your name in the forum it says you are running 2.95f. Do you know where I can download this version? maybe this will help the problem.
also, I have tried version 3.0.1 on both vista and xp and the "loop all" feature does not work on both.
