HELLO CAN ANYONE TELL ME IF IN THE SHAPE GENERATOR I CAN SELECT THAT SOME FIXTURE ROTATE TO THE LEFT AND OTHER ROTATE TO THE RIGHT?
THANK YOU!!!
SHAPES QUESTION Topic is solved
Papa C
Re: SHAPES QUESTION
Have you tried the inverse pan function.
I found this to work for me.
Select one of the fixtures and then right click over the fixture. Enable INVERSE PAN.
then when you select two or more AND run the shapes, the ones that have inverse pan will pan one direction while the others will pan the oppsite.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: SHAPES QUESTION
WHATS WITH THE SHOUTING LOL?
Right heres what you have to do, Set the fixtures to run the bezzier.
The select the beziers you want to run in the opersite direction.
Then select View next to the list box and click flipX, this will then make your shape rotate in the other direction.
