SGM Victory II
soundtruth
SGM Victory II
In the unlikely event anyone has any of these 250W scanners (they're pretty good actually) hope you find this handy. Complete with some macros. The profile is designed to work with the pan / tilt in 16 bit mode, not 8 bit.
Victory II.pff- (119.68 KiB) Downloaded 83 times
load
Re: SGM Victory II
Hi .. i have a couple of victory I ... do you have the fixture for this model?
- dmxlighting
- FreeStyler Version: beta
Re: SGM Victory II
Err maybe download the mk2 version and modify it to suit your needs?load wrote:Hi .. i have a couple of victory I ... do you have the fixture for this model?
load
Re: SGM Victory II
The problem is that I have already made a fixture for SGM 1 victory but I do not work properly .... controls respond correctly but I did not open the windows (windows -> All) and then I thought I had done something wrong in creating the fixture.
I have open your fixture in Fixture creator and i have downloaded the SGM Victory II manual for comparison with the victory 1 manual that I have.
But I don't have understood many things .... comparing the manual that I found in this link " http://www.rfsystems.nl/gebruiksaanwijz ... 302_E_.pdf " with the values you entered into your fixture I found the differences ... in the manual it says that there are 10 channels and instead you've made it 12.... i have open your fixture in freestyler and in the 11 and 12 channels ther are che pan 16bit and tilt 16 bit ... are like finepan and finetilt? looking better at the manual is written that the pan and tilt to 16bit are on channel 11 and 12 ....
Why you have insert in "goborot.1" the number 7? What does this mean?
Why you have insert in "goboch2" the number 9 .... in the 9 channer ther is the prism or not? and why there should be another channel for gobos?
Why you have insert 20 in the "number of colors" ... in the manual the colors are 16 + 8 reinbow speed + music hard change....
I'm no expert so I wonder why:
- You entered in the "shutter channel" in the "Open" 250 and not 255?
- In the Strobe channel "high" is in 142 and no in 149 (in the manual the max strobe value is 149)?
-You have insert frost channel but not the prism channel?
-In the channel description "locate and default value" have those value? Dimmer 255 - 0 / Shutter 250 - 0 / Pan and Tilt 127 - 0 ?
-the gobos value not corrispond whit the value of the manual?
- the color value not corrispond whit the value of the manual?
And what is the macros?
.... maybe the manual that I found is wrong???
As you see I have many questions because i'm not experienced and please to help me
soundtruth
Re: SGM Victory II
Hi, I entered the values that worked for me... e.g. 255 caused the shutter channel to close, but 250 was fully open. I wanted hi strobe to be not soo fast, hence the slightly lower value. The manuals are somtimes not the best guide. I could go on... I suggest you create your own profile that works for you. If you managed to make a fantastic profile, upload it so I can use it too.
Have fun.
Have fun.
