i made a mistake and bought the wrong USb2DMX Controller. I clicked in the wrong window. Now is my question:
Does this USB 2 DMX Controller work with Freestyler?
http://www.amazon.de/IMG-img-stage-line ... B0026R5WIK
Can someone help me ?
Thanks Philipp
does stage line dmx-1usb work?
- dmxlighting
- FreeStyler Version: beta
Re: does stage line dmx-1usb work?
Chances are that it will work but I dont know what profile you will need to use.
Try the Sunlight setup, that seems to work with alot of dongles. If not then go through them till you get one that does work.
Hopefully someone on here has one and can give a better answer than me!
