Used Freestyler 295 in the past with no problems. Created a fixture file for an old Martin Roboscan Pro 218. All the gobos and colours work fine. Including the bezier shapes pan and tilt.
Started up with new version 3.0.1 and re-created roboscan file because I lost the old one. All colours and gobos work fine but the shapes don't. I can manually adjust slider at top right window (dmx values for each channel) and pan and tilt work perfectly, However, dragging the mouse over the dot ( bezier shape window) does not do anything. (ie the pan and tilt dont work)
I know in this version, the auto dot doesn't work and that's ok but clicking the 'on' for a shape to work automatically or manually dragging the dot does nothing for my pan and tilt.
What am I doing wrong?
Please help and thank-you
BC
DESPERATE HELP!! Fixture doesn't work in auto!
- FreeStyler Version: 2.95f
Re: DESPERATE HELP!! Fixture doesn't work in auto!
Got the 16bit channels mixed up (stupid me)!!!
Got it thanks!
BC
Got it thanks!
BC
- djSupport
mu ha ha ha haaaaa
