Here is a fixture file for the American DJ Tri Phase LED.
For user convenience, I assigned Rotation to the gobo channel. This allows you to use the Gobo panel to select seven preset rotation speeds using pushbuttons. The seven speeds are the ones you'll commonly use, and you can still use the slider to fine-tune.
Similarly, the color channel has seven presets, and you can fine-tune your colors using the slider.
American DJ Tri Phase web page: http://www.americandj.com/ProductDetail ... umber=1842
GaryBonaducci
roobert
Re: American DJ Tri Phase LED
Thanks so much for posting these! This may be a noob question... but here goes. I recently bought 2 tri phase leds and was just going to set them up via dmx controller but came upon this site and thus purchased an enttec open dmx usb. I set everything up and loaded your fixture files. I'm able to control everything via the freestyler software except for when i set up a cue of something and try and run it... it either doesn't run anything or just gets stuck on a solid color... I get the warning signs from freestyler and I have to reset the inputs to re-gain control... do you have any idea as to why this is occuring? I can post a youtube video if it helps show what i'm describing. Thanks for any help!
-Rob
-Rob
GaryBonaducci
What "warning signs" do you get? I don't understand what's happening with your system.
roobert
It was totally user error
I got them responding to my usb device now. Do know if there's a way to use the sound active mode on the tri phases with dmx?
if you read the Manual for the American DJ Tri Phase LED, you will see you can't activate the sound to light function by dmx. you have to activtae it on the fixture itself or use the optional UC3 Controller from ADJ.
mr.quickly
Hello together,
I've customzied the Fixture for my needs. Maybe someone would like it.
- I've set the speed, the strobe and the dimmer via macros.
- New pictures included
Tri Phase LED.pff- (59.79 KiB) Downloaded 99 times
mr.quickly
Hello again,
I've made a new one using two gobo channels instead of macro only. On for rotation an one for strobe.
Via macro you can change the dimmer and set all channel values to zero.
Tri Phase LED-with-gobos.pff- (55.38 KiB) Downloaded 138 times
GaryBonaducci
Nice work with the custom color icons! I like the idea.
