Problem when I'm creating scenes Topic is solved
Drummerboyx
Post by Drummerboyx »
I have freestyler 3.01 and I can't create scenes. I go to create sequence icon and add one scene and it appears on the cue list but when I click on it the lights don't do the command. Any suggestions?
dmxlighting
FreeStyler Version: beta
Re: Problem when I'm creating scenes
Post by dmxlighting »
When you create a sequence make sure that the parameter you want to control is on snap or fade.
Example - Set the lamp to 'Snap', Movement 'Fade' etc. If these are in 'Off' mode then it will record the values to those channels but there will be no payback to see.
Hope that helps
Drummerboyx
Everything is set to snap. And it still does nothing.
Post by LJ_krede.dk »
see if these topics helps you:
Can only create cues "offline" and having fade issues?
Problems Creating Sequence
or try to read the help file to see if you are doing something wrong.
