faster fades? Topic is solved
sea
faster fades?
Post by sea »
It doesn't seem possible to shorten the fade time or the time between steps of a sequence. Has this been discussed before? Is there a reason? Is there a workaround? Half a second is pretty quick, but the tempo of some songs is quicker still.
Thanks again.
Re: faster fades?
do you mean shorter than the limit?? this might be able to be changed if you ask for it in the ideas and remarks but i could imagine if it was choosable as any speed some people might go faster than there machine can handle and cause real problems maybe it was implemented just like in pc games like command and conquer where in older versions you were limited to how many armys you could have etc cause if you overdid it then you computer would suffer the consequences... but i dont actually know
