Hi I've put on a couple of shows now and find the software great to use but i would like to be able to get the timer to work for the cues so i can 'prprogram ' for specific tunes .
ICan someone enlighten me on whether the timecode works or not as selecting it and programming times in the specific boxes has no effect to the cues starting !
Cheers in anticipation
Norm
TIME LINE
Normski2020
- Just started using FS
- FreeStyler Version: 3.2.1
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: TIME LINE
The time works with your clock. I.E 00.21.00 would start at either 21minutes past midnight or 21 minutes since the timer started.
You have to enable timecode first in the cue settings
Normski2020
Re: TIME LINE
Thanks but sadly i've tried that but the cues all start at the same time whether i select the realtime or the pc time! The timer buttons etc that appear seem to have no effect either
Norm
Norm
