M-Audio Trigger Finger
easyrider1340
Just started using FS
FreeStyler Version: 3.0.1
Post by easyrider1340 »
So, I've successfully set up an M-Audio Trigger Finger to control cues (using 16 available pads on Trigger Finger).
I'd like to be able to use the knobs and faders for various other functions, however I can't seem to accomplish this yet.
In another post, a member suggested that I could type in the note or cc value in the FS midi setup screen. Unfortunately, this option doesn't appear to be available. I can only assign note values based on input from the midi controller (no manual input possible).
Is this "the way it is"? Or can other input their own values?
The same member referenced a beta version. If this is available, I'd be willing to provide some feedback.
Thanks,
Terry M
dmxlighting
FreeStyler Version: beta
Re: M-Audio Trigger Finger
Post by dmxlighting »
Hi Terry
You used to be able to do this. I'll test it on my BCF2000 and get back to you.
Lee
Post by LJ_krede.dk »
It is only the beta version where you can assign midi notes or cc values in the midi setup screen , not in 3.0.1.
easyrider1340
Let me get in on the beta testing.
easy rider 1 3 4 0 @ gmail dot com.
- no spaces.
Thanks!
Terry
