i cant get the gobo rotation to work , i assigned both of them to knobs on my trigger finger and they dont do anything, is that a program issue, or a issues with the fixture file not being set up right , everything else works fine, shutter ect.
id like to have gobo rotation on a knob if possible but it doesn't seen to want to let me.
anyone have ideas?
im using martin scx 600's
midi controler and gobo rotate Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: midi controler and gobo rotate
Is this for 'Live' playback or for programming ?
Im not familiar with 'Trigger Finger' but the faders and rotarys on a BCF2000 work very well with FS so it may be down to what your unit is sending out and not a problem with FS.
You should be aware that during live play back from cues and submasters that you need to select the fixture to controll and assinged features in a manual mode.
It would be better to create a submaster stack for the gobo rotate control in live mode.
Download my sample show http://www.freestylersupport.com/fsforu ... =58&t=1394 as it shows this.
