Not sure if its relevant to your problem but the lastest version of Bcedit does not work properly.
When trying to upload to your BCF it will cause an error. Apparently this is down to some asci mismatches in the program.
Its still working ok for creating your own patches, then export your setting and use 'Bome's SendSX' to upload to the BCF.
If anyone is interested I will post MY setup for BCF2000. Its setup for 5 presets. Each preset leaves all buttons and rotarys the same, only the faders change.
Let me know if you want a copy!
Sorry, the file is not usable...
- dmxlighting
- FreeStyler Version: beta
Re: Sorry, the file is not usable...
- dmxlighting
Here is my BCF2000 set up.
It is comprised of 5 presets. Each preset only changes the channel numbers for the faders.
All other buttons and encoders remain on the same channels for every page.
This should be loaded into your BCF2000 and I reccommend using this program to do it....
You will need to assign midi control in fs setup, but thats a personal thing as to how you want it.
- dmxlighting
I used BcEdit.
There is a problem with BcEdit that means you cant upload to the BCF2000. Its a known problem and something to do with incorrect or unrecognised ascii's or something like that.
wardomon
Where did this file go? It's not linked at the Wiki either.
fs_setup syx.zip
fs_setup syx.zip
