"Sound to Light" run on startup?
djsno
FreeStyler Version: 3.4.4
Post by djsno »
Hey everyone,
Freestyler is great, I've just went to light switches and 3 separate lighting consoles to a nice rackmount touchscreen with freestyler. My question is... is there a way to have "sound to light" run on startup? My touchscreen interface it setup to display on startup of the computer, I don't want a keyboard or mouse hooked up. There is a "sound to light trigger" button you can put on the touchscreen interface but then it brings up the box to click start, then you have to try and get the freestyler touchscreen windows back to front. It's not a huge issue, just curious if anyone knows a way to do it. Thanks for the input.
Intel Core i7-3820, Corsair Vengence 32GB (8x4GB) DDR3 1866MHz, EVGA GTX-560Ti
Windows 8 Pro
Enttec DMX USB Pro (pre-built) FS 3.44
Re: "Sound to Light" run on startup?
Post by LJ_krede.dk »
i'm not sure, but i dont think there is a setting for that in Freestyler.
But maybe there is an alternative: use a macro recorder in windows that presses the necessary keys after FreeStyler is started.
A good working and free to use macro tool is WinMacro: http://www.geocities.com/win_macro/
djsno
Post by djsno »
Thanks! That is totally the way to go. It worked great.
Windows 8 Pro
I'm glad winmacro did the trick for you.
I can't take the credit for this solution thoug. It was remco_k who suggested it for another user to make a "Start of Night" cue.
